The network configuration is specified by declaring
and initializing the rtems_bsdnet_config
structure.
struct rtems_bsdnet_config { /* * This entry points to the head of the ifconfig chain. */ struct rtems_bsdnet_ifconfig *ifconfig; /* * This entry should be rtems_bsdnet_do_bootp if BOOTP * is being used to configure the network, and NULL * if BOOTP is not being used. */ void (*bootp)(void); /* * The remaining items can be initialized to 0, in * which case the default value will be used. */ rtems_task_priority network_task_priority; /* 100 */ unsigned long mbuf_bytecount; /* 64 kbytes */ unsigned long mbuf_cluster_bytecount; /* 128 kbytes */ char *hostname; /* BOOTP */ char *domainname; /* BOOTP */ char *gateway; /* BOOTP */ char *log_host; /* BOOTP */ char *name_server[3]; /* BOOTP */ char *ntp_server[3]; /* BOOTP */ };
The structure entries are described in the following table. If your application uses BOOTP/DHCP to obtain network configuration information and if you are happy with the default values described below, you need to provide only the first two entries in this structure.
void (*bootp)(void)
if your application will use BOOTP/DHCP
to obtain network configuration information.
It should be set to NULL
if your application does not use BOOTP/DHCP.
int network_task_priority
char *hostname
NULL
the value
may be obtained from a BOOTP/DHCP server.
char *domainname
char *gateway
129.128.4.1
) form.
char *log_host
syslog
messages
will be sent.
char *ntp_server[3]
In addition, the following fields in the rtems_bsdnet_ifconfig
are of interest.
