OAR
RTEMS 4.5.0 On-Line Library
Directive Status Codes
PREV UP NEXT Bookshelf RTEMS C User's Guide
Chapter 24: Directive Status Codes
RTEMS_SUCCESSFUL - successful completion
RTEMS_TASK_EXITTED - returned from a task
RTEMS_MP_NOT_CONFIGURED - multiprocessing not configured
RTEMS_INVALID_NAME - invalid object name
RTEMS_INVALID_ID - invalid object id
RTEMS_TOO_MANY - too many
RTEMS_TIMEOUT - timed out waiting
RTEMS_OBJECT_WAS_DELETED - object was deleted while waiting
RTEMS_INVALID_SIZE - invalid specified size
RTEMS_INVALID_ADDRESS - invalid address specified
RTEMS_INVALID_NUMBER - number was invalid
RTEMS_NOT_DEFINED - item not initialized
RTEMS_RESOURCE_IN_USE - resources outstanding
RTEMS_UNSATISFIED - request not satisfied
RTEMS_INCORRECT_STATE - task is in wrong state
RTEMS_ALREADY_SUSPENDED - task already in state
RTEMS_ILLEGAL_ON_SELF - illegal for calling task
RTEMS_ILLEGAL_ON_REMOTE_OBJECT - illegal for remote object
RTEMS_CALLED_FROM_ISR - invalid environment
RTEMS_INVALID_PRIORITY - invalid task priority
RTEMS_INVALID_CLOCK - invalid time buffer
RTEMS_INVALID_NODE - invalid node id
RTEMS_NOT_CONFIGURED - directive not configured
RTEMS_NOT_OWNER_OF_RESOURCE - not owner of resource
RTEMS_NOT_IMPLEMENTED - directive not implemented
RTEMS_INTERNAL_ERROR - RTEMS inconsistency detected
RTEMS_NO_MEMORY - could not get enough memory
