OAR
RTEMS 4.5.0 On-Line Library
Configuring a System ITRON API Configuration
PREV UP NEXT Bookshelf RTEMS C User's Guide
22.2.9: ITRON API Configuration
The parameters in this section are used to configure resources for the RTEMS ITRON API. They are only relevant if the POSIX API is enabled at configure time using the --enable-itron option.
