OAR
RTEMS 4.5.0 On-Line Library
Configuring a System Device Driver Table
PREV UP NEXT Bookshelf RTEMS C User's Guide
22.2.3: Device Driver Table
This section defines the configuration parameters related to the automatic generation of a Device Driver Table. As confdefs.h only is aware of a small set of standard device drivers, the generated Device Driver Table is suitable for simple applications with no custom device drivers.
