OAR
RTEMS 4.5.0 On-Line Library
User Extensions Manager EXTENSION_CREATE - Create a extension set
PREV UP NEXT Bookshelf RTEMS C User's Guide
21.4.1: EXTENSION_CREATE - Create a extension set
CALLING SEQUENCE:
rtems_status_code rtems_extension_create(
  rtems_name              name,
  rtems_extensions_table *table,
  rtems_id               *id
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - extension set created successfully
RTEMS_INVALID_NAME - invalid extension set name
RTEMS_TOO_MANY - too many extension sets created
DESCRIPTION:
This directive creates a extension set. The assigned extension set id is returned in id. This id is used to access the extension set with other user extension manager directives. For control and maintenance of the extension set, RTEMS allocates an ESCB from the local ESCB free pool and initializes it.
NOTES:
This directive will not cause the calling task to be preempted.
