OAR
RTEMS 4.5.0 On-Line Library
User Extensions Manager Extensions
PREV UP NEXT Bookshelf RTEMS C User's Guide
21.2.3: Extensions
  • User Extensions Manager TASK_CREATE Extension
  • User Extensions Manager TASK_START Extension
  • User Extensions Manager TASK_RESTART Extension
  • User Extensions Manager TASK_DELETE Extension
  • User Extensions Manager TASK_SWITCH Extension
  • User Extensions Manager TASK_BEGIN Extension
  • User Extensions Manager TASK_EXITTED Extension
  • User Extensions Manager FATAL Error Extension
  • The sections that follow will contain a description of each extension. Each section will contain a prototype of a function with the appropriate calling sequence for the corresponding extension. The names given for the C function and its arguments are all defined by the user. The names used in the examples were arbitrarily chosen and impose no naming conventions on the user.
