OAR
RTEMS 4.5.0 On-Line Library
User Extensions Manager Extension Sets
PREV UP NEXT Bookshelf RTEMS C User's Guide
21.2.1: Extension Sets
An extension set is defined as a set of routines which are invoked at each of the critical system events at which user extension routines are invoked. Together a set of these routines typically perform a specific functionality such as performance monitoring or debugger support. RTEMS is informed of the entry points which constitute an extension set via the following structure:
typedef struct {
  rtems_task_create_extension      thread_create;
  rtems_task_start_extension       thread_start;
  rtems_task_restart_extension     thread_restart;
  rtems_task_delete_extension      thread_delete;
  rtems_task_switch_extension      thread_switch;
  rtems_task_begin_extension       thread_begin;
  rtems_task_exitted_extension     thread_exitted;
  rtems_fatal_extension            fatal;
} rtems_extensions_table;
RTEMS allows the user to have multiple extension sets active at the same time. First, a single static extension set may be defined as the application's User Extension Table which is included as part of the Configuration Table. This extension set is active for the entire life of the system and may not be deleted. This extension set is especially important because it is the only way the application can provided a FATAL error extension which is invoked if RTEMS fails during the initialize_executive directive. The static extension set is optional and may be configured as NULL if no static extension set is required.
Second, the user can install dynamic extensions using the rtems_extension_create directive. These extensions are RTEMS objects in that they have a name, an ID, and can be dynamically created and deleted. In contrast to the static extension set, these extensions can only be created and installed after the initialize_executive directive successfully completes execution. Dynamic extensions are useful for encapsulating the functionality of an extension set. For example, the application could use extensions to manage a special coprocessor, do performance monitoring, and to do stack bounds checking. Each of these extension sets could be written and installed independently of the others.
All user extensions are optional and RTEMS places no naming restrictions on the user.
