OAR
RTEMS 4.5.0 On-Line Library
Rate Monotonic Manager RATE_MONOTONIC_DELETE - Delete a rate monotonic period
PREV UP NEXT Bookshelf RTEMS C User's Guide
19.4.4: RATE_MONOTONIC_DELETE - Delete a rate monotonic period
CALLING SEQUENCE:
rtems_status_code rtems_rate_monotonic_delete(
  rtems_id id
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - period deleted successfully
RTEMS_INVALID_ID - invalid rate monotonic period id
DESCRIPTION:
This directive deletes the rate monotonic period specified by id. If the period is running, it is automatically canceled. The PCB for the deleted period is reclaimed by RTEMS.
NOTES:
This directive will not cause the running task to be preempted.
A rate monotonic period can be deleted by a task other than the task which created the period.
