OAR
RTEMS 4.5.0 On-Line Library
Scheduling Concepts Dispatching Tasks
PREV UP NEXT Bookshelf RTEMS C User's Guide
18.2.5: Dispatching Tasks
The dispatcher is the RTEMS component responsible for allocating the processor to a ready task. In order to allocate the processor to one task, it must be deallocated or retrieved from the task currently using it. This involves a concept called a context switch. To perform a context switch, the dispatcher saves the context of the current task and restores the context of the task which has been allocated to the processor. Saving and restoring a task's context is the storing/loading of all the essential information about a task to enable it to continue execution without any effects of the interruption. For example, the contents of a task's register set must be the same when it is given the processor as they were when it was taken away. All of the information that must be saved or restored for a context switch is located either in the TCB or on the task's stacks.
Tasks that utilize a numeric coprocessor and are created with the RTEMS_FLOATING_POINT attribute require additional operations during a context switch. These additional operations are necessary to save and restore the floating point context of RTEMS_FLOATING_POINT tasks. To avoid unnecessary save and restore operations, the state of the numeric coprocessor is only saved when a RTEMS_FLOATING_POINT task is dispatched and that task was not the last task to utilize the coprocessor.
