OAR
RTEMS 4.5.0 On-Line Library
I/O Manager IO_WRITE - Write to a device
PREV UP NEXT Bookshelf RTEMS C User's Guide
16.4.7: IO_WRITE - Write to a device
CALLING SEQUENCE:
rtems_status_code rtems_io_write(
  rtems_device_major_number  major,
  rtems_device_minor_number  minor,
  void                      *argument
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - successfully initialized
RTEMS_INVALID_NUMBER - invalid major device number
DESCRIPTION:
This directive calls the device driver write routine specified in the Device Driver Table for this major number. Write operations typically require a buffer address as part of the argument parameter block. The contents of this buffer will be sent to the device.
NOTES:
This directive may or may not cause the calling task to be preempted. This is dependent on the device driver being invoked.
