OAR
RTEMS 4.5.0 On-Line Library
I/O Manager IO_LOOKUP_NAME - Lookup a device
PREV UP NEXT Bookshelf RTEMS C User's Guide
16.4.3: IO_LOOKUP_NAME - Lookup a device
CALLING SEQUENCE:
rtems_status_code rtems_io_lookup_name(
  const char                *name,
  rtems_driver_name_t      **device_info
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - successfully initialized
RTEMS_UNSATISFIED - name not registered
DESCRIPTION:
This directive returns the major/minor number pair associated with the given device name in device_info.
NOTES:
This directive will not cause the calling task to be preempted.
