OAR
RTEMS 4.5.0 On-Line Library
I/O Manager IO_INITIALIZE - Initialize a device driver
PREV UP NEXT Bookshelf RTEMS C User's Guide
16.4.1: IO_INITIALIZE - Initialize a device driver
CALLING SEQUENCE:
rtems_status_code rtems_io_initialize(
  rtems_device_major_number  major,
  rtems_device_minor_number  minor,
  void                      *argument
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - successfully initialized
RTEMS_INVALID_NUMBER - invalid major device number
DESCRIPTION:
This directive calls the device driver initialization routine specified in the Device Driver Table for this major number. This directive is automatically invoked for each device driver when multitasking is initiated via the initialize_executive directive.
A device driver initialization module is responsible for initializing all hardware and data structures associated with a device. If necessary, it can allocate memory to be used during other operations.
NOTES:
This directive may or may not cause the calling task to be preempted. This is dependent on the device driver being initialized.
