OAR
RTEMS 4.5.0 On-Line Library
I/O Manager Register and Lookup Name
PREV UP NEXT Bookshelf RTEMS C User's Guide
16.3.1: Register and Lookup Name
The rtems_io_register directive associates a name with the specified device (i.e. major/minor number pair). Device names are typically registered as part of the device driver initialization sequence. The rtems_io_lookup directive is used to determine the major/minor number pair associated with the specified device name. The use of these directives frees the application from being dependent on the arbitrary assignment of major numbers in a particular application. No device naming conventions are dictated by RTEMS.
