OAR
RTEMS 4.5.0 On-Line Library
I/O Manager Device Driver Table
PREV UP NEXT Bookshelf RTEMS C User's Guide
16.2.1: Device Driver Table
Each application utilizing the RTEMS I/O manager must specify the address of a Device Driver Table in its Configuration Table. This table contains each device driver's entry points. Each device driver may contain the following entry points:
If the device driver does not support a particular entry point, then that entry in the Configuration Table should be NULL. RTEMS will return RTEMS_SUCCESSFUL as the executive's and zero (0) as the device driver's return code for these device driver entry points.
