OAR
RTEMS 4.5.0 On-Line Library
Dual-Ported Memory Manager PORT_EXTERNAL_TO_INTERNAL - Convert external to internal address
PREV UP NEXT Bookshelf RTEMS C User's Guide
15.4.4: PORT_EXTERNAL_TO_INTERNAL - Convert external to internal address
CALLING SEQUENCE:
rtems_status_code rtems_port_external_to_internal(
  rtems_id   id,
  void      *external,
  void     **internal
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - always successful
DESCRIPTION:
This directive converts a dual-ported memory address from external to internal representation for the specified port. If the given external address is invalid for the specified port, then the internal address is set to the given external address.
NOTES:
This directive is callable from an ISR.
This directive will not cause the calling task to be preempted.
