OAR
RTEMS 4.5.0 On-Line Library
Dual-Ported Memory Manager Creating a Port
PREV UP NEXT Bookshelf RTEMS C User's Guide
15.3.1: Creating a Port
The rtems_port_create directive creates a port into a DPMA with the user-defined name. The user specifies the association between internal and external representations for the port being created. RTEMS allocates a Dual-Ported Memory Control Block (DPCB) from the DPCB free list to maintain the newly created DPMA. RTEMS also generates a unique dual-ported memory port ID which is returned to the calling task. RTEMS does not initialize the dual-ported memory area or access any memory within it.
