OAR
RTEMS 4.5.0 On-Line Library
Signal Manager Building an ASR Mode
PREV UP NEXT Bookshelf RTEMS C User's Guide
12.2.4: Building an ASR Mode
In general, an ASR's mode is built by a bitwise OR of the desired mode components. The set of valid mode components is the same as those allowed with the task_create and task_mode directives. A complete list of mode options is provided in the following table:
Mode values are specifically designed to be mutually exclusive, therefore bitwise OR and addition operations are equivalent as long as each mode appears exactly once in the component list. A mode component listed as a default is not required to appear in the mode list, although it is a good programming practice to specify default components. If all defaults are desired, the mode DEFAULT_MODES should be specified on this call.
This example demonstrates the mode parameter used with the rtems_signal_catch to establish an ASR which executes at interrupt level three and is non-preemptible. The mode should be set to RTEMS_INTERRUPT_LEVEL(3) | RTEMS_NO_PREEMPT to indicate the desired processor mode and interrupt level.
