OAR
RTEMS 4.5.0 On-Line Library
Event Manager Building an Event Set or Condition
PREV UP NEXT Bookshelf RTEMS C User's Guide
11.2.2: Building an Event Set or Condition
An event set or condition is built by a bitwise OR of the desired events. The set of valid events is RTEMS_EVENT_0 through RTEMS_EVENT_31. If an event is not explicitly specified in the set or condition, then it is not present. Events are specifically designed to be mutually exclusive, therefore bitwise OR and addition operations are equivalent as long as each event appears exactly once in the event set list.
For example, when sending the event set consisting of RTEMS_EVENT_6, RTEMS_EVENT_15, and RTEMS_EVENT_31, the event parameter to the rtems_event_send directive should be RTEMS_EVENT_6 | RTEMS_EVENT_15 | RTEMS_EVENT_31.
