OAR
RTEMS 4.5.0 On-Line Library
Message Manager Obtaining Message Queue IDs
PREV UP NEXT Bookshelf RTEMS C User's Guide
10.3.2: Obtaining Message Queue IDs
When a message queue is created, RTEMS generates a unique message queue ID. The message queue ID may be obtained by either of two methods. First, as the result of an invocation of the rtems_message_queue_create directive, the queue ID is stored in a user provided location. Second, the queue ID may be obtained later using the rtems_message_queue_ident directive. The queue ID is used by other message manager directives to access this message queue.
