OAR
RTEMS 4.5.0 On-Line Library
Message Manager Message Queues
PREV UP NEXT Bookshelf RTEMS C User's Guide
10.2.2: Message Queues
A message queue permits the passing of messages among tasks and ISRs. Message queues can contain a variable number of messages. Normally messages are sent to and received from the queue in FIFO order using the rtems_message_queue_send directive. However, the rtems_message_queue_urgent directive can be used to place messages at the head of a queue in LIFO order.
Synchronization can be accomplished when a task can wait for a message to arrive at a queue. Also, a task may poll a queue for the arrival of a message.
The maximum length message which can be sent is set on a per message queue basis.
