rtems_status_code rtems_timer_reset( rtems_id id );
RTEMS_SUCCESSFUL
- timer reset successfully
RTEMS_INVALID_ID
- invalid timer id
RTEMS_NOT_DEFINED
- attempted to reset a when or newly created timer
This directive resets the timer associated with id.
This timer must have been previously initiated with a
rtems_timer_fire_after
directive. If active the timer is canceled,
after which the timer is reinitiated using the same interval and
timer service routine which the original
directive used.
If the timer has not been used or the last usage of this timer
was by a rtems_timer_fire_when
directive, then the RTEMS_NOT_DEFINED
error is
returned.
Restarting a cancelled after timer results in the timer being reinitiated with its previous timer service routine and interval.
This directive will not cause the running task to be preempted.
