OAR
RTEMS 4.5.0 On-Line Library
Timer Manager TIMER_CREATE - Create a timer
PREV UP NEXT Bookshelf RTEMS C User's Guide
8.4.1: TIMER_CREATE - Create a timer
CALLING SEQUENCE:
rtems_status_code rtems_timer_create(
  rtems_name  name,
  rtems_id   *id
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - timer created successfully
RTEMS_INVALID_NAME - invalid timer name
RTEMS_TOO_MANY - too many timers created
DESCRIPTION:
This directive creates a timer. The assigned timer id is returned in id. This id is used to access the timer with other timer manager directives. For control and maintenance of the timer, RTEMS allocates a TMCB from the local TMCB free pool and initializes it.
NOTES:
This directive will not cause the calling task to be preempted.
