OAR
RTEMS 4.5.0 On-Line Library
Timer Manager Deleting a Timer
PREV UP NEXT Bookshelf RTEMS C User's Guide
8.3.7: Deleting a Timer
The rtems_timer_delete directive is used to delete a timer. If the timer is running and has not expired, the timer is automatically canceled. The timer's control block is returned to the TMCB free list when it is deleted. A timer can be deleted by a task other than the task which created the timer. Any subsequent references to the timer's name and ID are invalid.
