OAR
RTEMS 4.5.0 On-Line Library
Clock Manager Announcing a Tick
PREV UP NEXT Bookshelf RTEMS C User's Guide
7.3.1: Announcing a Tick
RTEMS provides the rtems_clock_tick directive which is called from the user's real-time clock ISR to inform RTEMS that a tick has elapsed. The tick frequency value, defined in microseconds, is a configuration parameter found in the Configuration Table. RTEMS divides one million microseconds (one second) by the number of microseconds per tick to determine the number of calls to the rtems_clock_tick directive per second. The frequency of rtems_clock_tick calls determines the resolution (granularity) for all time dependent RTEMS actions. For example, calling rtems_clock_tick ten times per second yields a higher resolution than calling rtems_clock_tick two times per second. The rtems_clock_tick directive is responsible for maintaining both calendar time and the dynamic set of timers.
