OAR
RTEMS 4.5.0 On-Line Library
Clock Manager Required Support
PREV UP NEXT Bookshelf RTEMS C User's Guide
7.2.1: Required Support
For the features provided by the clock manager to be utilized, periodic timer interrupts are required. Therefore, a real-time clock or hardware timer is necessary to create the timer interrupts. The rtems_clock_tick directive is normally called by the timer ISR to announce to RTEMS that a system clock tick has occurred. Elapsed time is measured in ticks. A tick is defined to be an integral number of microseconds which is specified by the user in the Configuration Table.
