OAR
RTEMS 4.5.0 On-Line Library
Interrupt Manager INTERRUPT_CATCH - Establish an ISR
PREV UP NEXT Bookshelf RTEMS C User's Guide
6.4.1: INTERRUPT_CATCH - Establish an ISR
CALLING SEQUENCE:
rtems_status_code rtems_interrupt_catch(
  rtems_isr_entry      new_isr_handler,
  rtems_vector_number  vector,
  rtems_isr_entry     *old_isr_handler
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - ISR established successfully
RTEMS_INVALID_NUMBER - illegal vector number
RTEMS_INVALID_ADDRESS - illegal ISR entry point or invalid old_isr_handler
DESCRIPTION:
This directive establishes an interrupt service routine (ISR) for the specified interrupt vector number. The new_isr_handler parameter specifies the entry point of the ISR. The entry point of the previous ISR for the specified vector is returned in old_isr_handler.
To release an interrupt vector, pass the old handler's address obtained when the vector was first capture.
Passing a NULL pointer as the old_handler address and this parameter will be ignored.
NOTES:
This directive will not cause the calling task to be preempted.
