OAR
RTEMS 4.5.0 On-Line Library
Task Manager TASK_GET_NOTE - Get task notepad entry
PREV UP NEXT Bookshelf RTEMS C User's Guide
5.4.11: TASK_GET_NOTE - Get task notepad entry
CALLING SEQUENCE:
rtems_status_code rtems_task_get_note(
  rtems_id          id,
  rtems_unsigned32  notepad,
  rtems_unsigned32 *note
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - note obtained successfully
RTEMS_INVALID_ID - invalid task id
RTEMS_INVALID_NUMBER - invalid notepad location
DESCRIPTION:
This directive returns the note contained in the notepad location of the task specified by id.
NOTES:
This directive will not cause the running task to be preempted.
If id is set to RTEMS_SELF, the calling task accesses its own notepad.
The sixteen notepad locations can be accessed using the constants RTEMS_NOTEPAD_0 through RTEMS_NOTEPAD_15.
Getting a note of a global task which does not reside on the local node will generate a request to the remote node to obtain the notepad entry of the specified task.
