OAR
RTEMS 4.5.0 On-Line Library
Discrete Driver Open a Particular Discrete Bitfield
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
16.4: Open a Particular Discrete Bitfield
This is the driver open call. Usually this call does nothing other than validate the minor number.
With some drivers, it may be necessary to allocate memory when a particular device is opened. If that is the case, then this is often the place to do this operation.
