OAR
RTEMS 4.5.0 On-Line Library
Analog Driver Close a Particular Analog
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
15.5: Close a Particular Analog
This is the driver close call. Usually this call does nothing.
With some drivers, it may be necessary to allocate memory when a particular device is opened. If that is the case, then this is the place where that memory should be deallocated.
