OAR
RTEMS 4.5.0 On-Line Library
Analog Driver Initialize an Analog Board
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
15.3: Initialize an Analog Board
At system initialization, the analog driver's initialization entry point will be invoked. As part of initialization, the driver will perform whatever board initialization is required and then set all outputs to their configured initial state.
The analog driver may register a device name for each DAC and ADC in the system.
