OAR
RTEMS 4.5.0 On-Line Library
Shared Memory Support Driver Acquiring a Shared Lock
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
14.2.3.2: Acquiring a Shared Lock
The Shm_Lock routine is responsible for acquiring the lock field. Interrupts should be disabled while that lock is acquired. If the lock is currently unavailble, then the locking routine should delay a few microseconds to allow the other node to release the lock. Doing this reduces bus contention for the lock. This routines usually is implemented as follows:
void Shm_Lock(
  Shm_Locked_queue_Control *lq_cb
  disable processor interrupts
    set Shm_isrstat to previous interrupt disable level
    while ( TRUE ) {
      atomically attempt to acquire the lock
      if the lock was acquired
        return
      delay some small period of time
