OAR
RTEMS 4.5.0 On-Line Library
Shared Memory Support Driver Installing the MPCI ISR
PREV UP next Bookshelf BSP and Device Driver Development Guide
14.3: Installing the MPCI ISR
The Shm_setvec is invoked by the portable portion of the shared memory to install the interrupt service routine that is invoked when an incoming message is announced. Some target boards support an interprocessor interrupt or mailbox scheme and this is where the ISR for that interrupt would be installed.
On an interrupt driven node, this routine would be implemented as follows:
void Shm_setvec( void )
  install the interprocessor communications ISR
On a polled node, this routine would be empty.
