OAR
RTEMS 4.5.0 On-Line Library
Networking Driver Write the Driver Interrupt Handler
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
13.10: Write the Driver Interrupt Handler
A typical interrupt handler will do nothing more than the hardware manipulation required to acknowledge the interrupt and send an RTEMS event to wake up the driver receive or transmit task waiting for the event. Network interface interrupt handlers must not make any calls to other network routines.
