OAR
RTEMS 4.5.0 On-Line Library
Networking Driver Introduction
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
13.1: Introduction
This chapter is intended to provide an introduction to the procedure for writing RTEMS network device drivers. The example code is taken from the `Generic 68360' network device driver. The source code for this driver is located in the c/src/lib/libbsp/m68k/gen68360/network directory in the RTEMS source code distribution. Having a copy of this driver at hand when reading the following notes will help significantly.
