OAR
RTEMS 4.5.0 On-Line Library
Real-Time Clock Driver setRealTimeToRTEMS
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
11.3: setRealTimeToRTEMS
The setRealTimeToRTEMS routine sets the current RTEMS TOD to that of the preferred RTC.
void setRealTimeToRTEMS(void)
  if no RTCs are present
    return
  invoke the deviceGetTime routine for the preferred RTC
  set the RTEMS TOD using rtems_clock_set
