OAR
RTEMS 4.5.0 On-Line Library
Clock Driver Ticks Counter
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
9.2.2: Ticks Counter
Most of the clock device drivers provide a global variable that is simply a count of the number of clock driver interrupt service routines that have occured. This information is valuable when debugging a system. This variable is declared as follows:
volatile rtems_unsigned32 Clock_driver_ticks;
