OAR
RTEMS 4.5.0 On-Line Library
Miscellaneous Support Files bsp.h Include File
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
5.5: bsp.h Include File
The file include/bsp.h contains prototypes and definitions specific to this board. Every BSP is required to provide a bsp.h. The best approach to writing a bsp.h is copying an existing one as a starting point.
Many bsp.h files provide prototypes of variables defined in the linker script (linkcmds).
There are a number of fields in this file that are used only by the RTEMS Test Suites. The following is a list of these:
