OAR
RTEMS 4.5.0 On-Line Library
Miscellaneous Support Files times
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
5.3: times
This file contains the results of the RTEMS Timing Test Suite. It is in a standard format so that results from one BSP can be easily compared with those of another target board.
If a BSP supports multiple variants, then there may be multiple times files. Usually these are named times.VARIANTn.
