OAR
RTEMS 4.5.0 On-Line Library
Linker Script What is a "linkcmds" file?
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
4.1: What is a "linkcmds" file?
The linkcmds file is a script which is passed to the linker at linking time. This file describes the memory configuration of the board as needed to link the program. Specifically it specifies where the code and data for the application will reside in memory.
