OAR
RTEMS 4.5.0 On-Line Library
Target Dependent Files Board Support Package Structure
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
2.7: Board Support Package Structure
The BSPs are all under the c/src/lib/libbsp directory. Below this directory, there is a subdirectory for each CPU family. Each BSP is found under the subdirectory for the appropriate processor family (m68k, powerpc, etc.). In addition, there is source code available which may be shared across all BSPs regardless of the CPU family or just across BSPs within a single CPU family. This results in a BSP using the following directories:
c/src/lib/libbsp/shared
c/src/lib/libbsp/CPU/shared
c/src/lib/libbsp/CPU/BSP
Under each BSP specific directory, there is a collection of subdirectories. For commonly provided functionality, the BSPs follow a convention on subdirectory naming. The following list describes the commonly found subdirectories under each BSP.
The build order of the BSP is determined by the Makefile structure. This structure is discussed in more detail in the Makefiles chapter.
NOTE: This manual refers to the gen68340 BSP for numerous concrete examples. You should have a copy of the gen68340 BSP available while reading this piece of documentation. This BSP is located in the following directory:
c/src/lib/libbsp/m68k/gen68340
Later in this document, the $BSP340_ROOT label will be used to refer to this directory.
