OAR
RTEMS 4.5.0 On-Line Library
Target Dependent Files Questions to Ask
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
2.4: Questions to Ask
When evaluating what is required to support RTEMS applications on a particular target board, the following questions should be asked:
If there is already a BSP for the board, then things may already be ready to start developing application software. All that remains is to verify that the existing BSP provides device drivers for all the peripherals on the board that the application will be using. For example, the application in question may require that the board's Ethernet controller be used and the existing BSP may not support this.
If the BSP does not exist and the board's CPU model is supported, then examine the reusable chip library and existing BSPs for a close match. Other BSPs and libchip provide starting points for the development of a new BSP. It is often possible to copy existing components in the reusable chip library or device drivers from BSPs from different CPU families as the starting point for a new device driver. This will help reduce the development effort required.
If the board's CPU family is supported but the particular CPU model on that board is not, then the RTEMS port to that CPU family will have to be augmented. After this is done, development of the new BSP can proceed.
Otherwise both CPU dependent code and the BSP will have to be written.
Regardless of the amount of development required, OAR Corporation offers custom development services to assist RTEMS users. For more information on custom development, training courses, and support, contact OAR Corporation at .
