OAR
RTEMS 4.5.0 On-Line Library
Multiprocessing Manager MULTIPROCESSING_ANNOUNCE - Announce the arrival of a packet
23.5.1: MULTIPROCESSING_ANNOUNCE - Announce the arrival of a packet
CALLING SEQUENCE:
procedure Multiprocessing_Announce;
DIRECTIVE STATUS CODES:
NONE
DESCRIPTION:
This directive informs RTEMS that a multiprocessing communications packet has arrived from another node. This directive is called by the user-provided MPCI, and is only used in multiprocessor configurations.
NOTES:
This directive is typically called from an ISR.
This directive will almost certainly cause the calling task to be preempted.
This directive does not generate activity on remote nodes.
