OAR
RTEMS 4.5.0 On-Line Library
Multiprocessing Manager Announcing a Packet
23.4.1: Announcing a Packet
The rtems.multiprocessing_announce directive is called by the MPCI layer to inform RTEMS that a packet has arrived from another node. This directive can be called from an interrupt service routine or from within a polling routine.
