OAR
RTEMS 4.5.0 On-Line Library
Multiprocessing Manager RECEIVE_PACKET
23.3.4: RECEIVE_PACKET
The RECEIVE_PACKET component of the user-provided MPCI layer is called when RTEMS needs to obtain a packet which has previously arrived. This component should be adhere to the following prototype:
procedure User_MPCI_Receive_Packet (
   Packet : access RTEMS.Packet_Prefix_Pointer
where packet is a pointer to the address of a packet to place the message from another node. If a message is available, then packet will contain the address of the message from another node. If no messages are available, this entry packet should contain NULL.
