OAR
RTEMS 4.5.0 On-Line Library
Multiprocessing Manager GET_PACKET
23.3.2: GET_PACKET
The GET_PACKET component of the user-provided MPCI layer is called when RTEMS must obtain a packet buffer to send or broadcast a message. This component should be adhere to the following prototype:
procedure User_MPCI_Get_Packet (
   Packet : access RTEMS.Packet_Prefix_Pointer
where packet is the address of a pointer to a packet. This routine always succeeds and, upon return, packet will contain the address of a packet. If for any reason, a packet cannot be successfully obtained, then the fatal error manager should be invoked.
RTEMS has been optimized to avoid the need for obtaining a packet each time a message is sent or broadcast. For example, RTEMS sends response messages (RR) back to the originator in the same packet in which the request message (RQ) arrived.
