OAR
RTEMS 4.5.0 On-Line Library
Multiprocessing Manager Multiprocessor Configuration Table
23.2.6: Multiprocessor Configuration Table
The Multiprocessor Configuration Table contains information needed by RTEMS when used in a multiprocessor system. This table is discussed in detail in the section Multiprocessor Configuration Table of the Configuring a System chapter.
