OAR
RTEMS 4.5.0 On-Line Library
Configuring a System POSIX Initialization Threads Table Configuration
22.2.8: POSIX Initialization Threads Table Configuration
The confdefs.h configuration system can automatically generate a POSIX Initialization Threads Table named POSIX_Initialization_threads with a single entry. The following parameters control the generation of that table.
