OAR
RTEMS 4.5.0 On-Line Library
Configuring a System Multiprocessing Configuration
22.2.4: Multiprocessing Configuration
This section defines the multiprocessing related system configuration parameters supported by confdefs.h. This class of Configuration Constants are only applicable if CONFIGURE_MP_APPLICATION is defined.
