OAR
RTEMS 4.5.0 On-Line Library
Configuring a System Basic System Information
22.2.2: Basic System Information
This section defines the general system configuration parameters supported by confdefs.h.
NOTE: The required size of the Executive RAM Work Area is calculated automatically when using the confdefs.h mechanism.
