The Device Driver Table is used to inform the I/O Manager of the set of entry points for each device driver configured in the system. The table contains one entry for each device driver required by the application. The number of entries is defined in the number_of_device_drivers entry in the Configuration Table. The format of each entry in the Device Driver Table is defined in the following Ada record:
type Driver_Address_Table_Entry is record Initialization : RTEMS.Device_Driver_Entry; Open : RTEMS.Device_Driver_Entry; Close : RTEMS.Device_Driver_Entry; Read : RTEMS.Device_Driver_Entry; Write : RTEMS.Device_Driver_Entry; Control : RTEMS.Device_Driver_Entry; end record; type Driver_Address_Table is array ( RTEMS.Unsigned32 range <> ) of RTEMS.Driver_Address_Table_Entry; type Driver_Address_Table_Pointer is access all Driver_Address_Table;
rtems.io_initialize
to initialize a device driver and its associated devices.
rtems.io_open
rtems.io_close
rtems.io_read
rtems.io_write
rtems.io_control
Driver entry points configured as NULL will always
return a status code of RTEMS.SUCCESSFUL
. No user code will be
executed in this situation.
A typical declaration for a Device Driver Table might appear as follows:
More information regarding the construction and operation of device drivers is provided in the I/O Manager chapter.
